As suggested in a previous thread, I am posting up my initial review of the WattNode I bought for monitoring my home power usage.
I bought the Advanced Wattnode Pulse (http://www.ccontrolsys.com/products/pulse_output.html) to monitor my 200 amp 240vac service. I picked this solution as it would scale with two additional current transformers for when we upgrade to 400 amp service. It also can monitor reverse power should I ever decide to put a solar array or wind generator up.
I had the unit setup for outputting pulses at a higher than normal rate. (5333 pulses per KW/hr) (80HZ) as well as the default 20Hz rate. This would enable me to graph and log smaller changes in power usage, such as the turning on of a 100 watt bulb in the past minute.
I currently have a 1-wire DS2423 chip monitoring the pulses at both output scales.
I have a perl script gathering the pulse count every 60 seconds and inserting a new record into mysql of the current counter reading. This has been working well for about 4 days so far.
I am still trying to figure out how to interpret the data as I only input the raw data, not the count change. If anyone has some mysql logic/scripts for processing the counts of a DS2423 chip and is willing to share them with me, I would appreciate it.
Once I have the frontend graph functions figured out, I'll try to post up additional information on how the system has been working out.
