Hello, All...
I've got a pretty extensive Insteon setup going now... I've been building up a bit a at a time. I seem to be having a bit of an intermittent communication problem that had me confused but I think I've narrowed the problem down to some combination of the furnace fan and/or the AC unit. Of course, I'm sure there are other sources of noise in the house but this seems to be the key for the moment.
The furnace itself is a DC motor and 120v and is hardwired to the electrical panel. I can pretty easily try to filter this by adding the following:
can't post links
--> (XFP - X10 PRO Inline Noise Filter 120v)
According to the datasheet, 2x of these can be added across 2 phases to filter 220v loads. That's all well and good but my AC unit is running through a 40A double pole breaker.
1) Is there a similar product for use on higher current applications?
2) Maybe wire 4x with 2x on each phase and in parallel to double the total current capacity?
3) Although for X10 originally, I assume this will do the trick for Insteon too?
comments? any/all help is appreciated.
thanx.
can't post links
thanx.
