I am having problems. I maybe just do not understand the linking.
PLC=2414S with Icon dimmers
I have the links in the plc for the lights and can control them but they dont report the status back I always get a getonleveltext=send failed.
If I try to check the links in the switch itself i get "Command aborted, no controller for this light" from the mainlobby insteon plugin. Some of them dont get the error but never report anything back.
Everything worked fine until I swapped out the PLC for a newer one. (revision upgrade) The icons used to have links in them 1 for slv and one for mas.
I assume I need to link the plc to the switch, then link the switch to the plc. If so what is the procedure for this? I have tried alot of stuff with no results.
