I don't think Elk, nor any other company will ever publish a roadmap or talk about a feature before it is already on the board or in Beta. Too many get burned when they talk about stuff and then for whatever reason abandon it. Elk has however, mainly thru David frequenting this forum announced or hinted at some new things we will see. A new version of firmware for the XEP along with a new version of RP is due out shortly. Several versions of keypad and touch screens due out probably Q1 next year. An 'M2' with more processor power and capability has been hinted at as a possible next step. Various other additions to firmware and RP also discussed. I think Elk will continue to rely on other 'best in breed' devices like the Ocelot to provide IR, etc., although I would not be surprised if they built in some support for some of these technologies on their own. They seem to be very aggressive in adding new features and components and seem customer driven (Squeeky wheels as David says).
Also wanted to make a point about the 'Homerunner' for Stargate. Not to take anything away from it, it sounds very nice, but wanted to point out that similar things can be accomplished with other tools. Maybe not as simply, but doable.
Assuming you go with a hardware controller which I believe nobody would argue with - you could always supplement it with software for fluff and design. For example, I can use Charmed Quark(CQC), also mentioned here - see the recent announcement of 1.5, as a set of interfaces for a touch screen. This is exactly what I am doing with the M1. The beauty of CQC interface design is that it is open - you can use your own images or graphics and build the system to look however you want. It can be built to look like Homerunner using schematics of the house, or it can be as simple as stock buttons and text. The beauty is you are not locked into whatever the program produces. Of course the downside, as always, is it takes more work to have it look totally custom. As a benefit, you can also use CQC to supplement the panels weaknesses. There are drivers in CQC for the M1 and HAI, unfortuntaely not the Stargate as has been discussed here too. But it is doable if needed. Another alternative is Mainlobby which will also interface to many panels. The only downside to Mainlobby is it is geared mainly toward interface design, not a complete HT and HA solution as CQC is.
Which brings up something I did not see mentioned - in a home this size, is there a home theater you are looking at including in the automation? If so, then I especially recommend taking a look at CQC. HT is their strength and original target market. You can then have the core of your system being the hardware controller and CQC which will cover all your security, theater and most HA needs. Then just supplement with other bits as needed.
Last point, also an opinion, but I believe perimeter security still rules. I want to stop a criminal BEFORE they get in and trip internal sensors. I belive it is well worth securing all possible perimeter entries and use the motions, etc as a backup in addition to automation triggers. If you can't get a wire to a location, you can supplement with a good wireless like GE/Caddx which at least the M1 supports (not sure about JDS). In a multistory home, I would AT LEAST protect the perimeter on the ground floor. Specialized motions on the EXTERIOR are also not a bad idea. There are even some cool things like tripping sprinklers based on outdoor motion to ward off prowlers. Just please, don't wait until they are inside, especially with children before alerting you or the authorities.
		 Just kidding - I just adquired an M1.
