I am trying to put all my source equipment (like many of us) into a single wiring closet in the basement. There are so many IR distribution options out there that, frankly, I am a bit overwhelmed. I think I understand that I need something like a Xantech distribution block (79520) with IR receivers in every room (I prefer the in-wall J-box style).
My questions are:
1) Is cat5e or cat6 sufficient for this? Xantech's website says you can go up to 200 feet with 24gauge conductors.
2) Are there any issues with specific source equipment? (for example, HDMI over cat5/6 baluns does not work very well...any similar problems with IR over cat5/6?)
3) How do I control Xbox? AFAIK, their wireless controllers are RF and not IR.
4) How do I tie all this into my OmniPro panel for some automation (for example, turn off unused equipment at night if someone forgets to turn it off)? Do I need something like a GC-100?
Today we use a Harmony IR remote (not RF capable - but willing upgrade if it solves some of the problems) so I would prefer the user interface to remain the same. Appreciate any pointers/feedback on this.
[EDIT] Forgot to mention that I will have cable box, blu ray player, receiver, xbox, mythtv frontend, Nuvo E6G in the wiring closet
[/EDIT]
I have a similar setup.
- All equipment except for a couple PS3s and an Xbox are in a central closet. Everything happens in the closet, including HD switching and distribution.
- All the zone switching and source distribution heavy lifting is done by 3 receivers (Yamaha with 3 zones, Integra with 3 zones, and a Marantz with 1 zone), an HDMI matrix, and some amplified RCA/Coax/Optical distribution buses
- I ran 3 runs of HDMI from bluejean cables to the home theater room and the main family room. There is a local PS3 in these rooms for playing games, and an HDTV/Projector/surround sound setup.
- Among other CAT5 runs, I ran a dedicated CAT5 cable to every room that required an IR receiver, my original design called for an IR receiver in most rooms.
IR Design #1:
- Xantech system. I started with the 4-zone 79520 unit connected to 9 IR receivers over CAT5. I didn't end up using the zoned capability, so I dropped back to a 79144 with a CB12 wiring block. The unit you pick really depends only on two things. 1) Do you need zones? Probably not unless you are using many of the same piece of equipment. 2) How many transmitters do you need? They make units that have two emitters per connection, so with a 79144 you can get 20 IR emitters, and expand to get another 20 if you need it. You will need their biggest power supply if you are going to have a lot of receivers and transmitters.
- All receivers are connected to the connecting block using only 3 conductors in the CAT5 line. I could use more, but 3 works fine. Probably several hundred feet in total CAT5 distance.
- I bought 10 Pronto TSU2000s to act as the IR "automation" brain.
- The Pronto program I put together requires that you pick a room before you start running IR macros, so the solution scaled pretty well over the last 10 years. It could "locally" control the TV in the room, so I did not have to run an emitter from the closet to the TVs or Projector.
- IR noise was an issue in the room with the Plasma TV, so I had to buy a fancy receiver designed to work with Plasma TVs (ug..not a cheap component)
- All in all, rock solid for 10 years. The Xantech stuff is indestructible.
IR Design #2:
- Same Xantech system as #1, but I no longer need it for the receivers in each room. I am moving to a series of iPad remotes over wifi, so I don't need a receiver in each room anymore. My goal was to create a totally integrated user experience that includes lighting, IR control, alarm, sprinklers, HVAC, Pool, Etc. I am doing this with HomeSeer and HSTouch.
- Since I could no longer use the universal remote's IR output to control the local components in each room, I used the same connecting blocks that the receivers plugged into to run an IR emitter to the TV/Game console. Alternatively you could put an Ethernet->IR or Wifi->IR box at each TV.
- After a lot of heart burn over getting stuck in the middle of Bitwise's recent decision to drop out of the DIY market, I ended up sticking with a Bitwise BC4X. It is superior solution in every way, plus you can still get hardware from HAI, so I bought a spare. Globalcache is an option, but the integration with HomeSeer is painful/eye-stabbingly tedious.
To answers your questions directly:
1) Cat5/5e/6 is sufficient. I would go with Cat6 if cost is no object.
2) If you go Xantech, everything will be rock solid. No issues with using Cat5.
3) XBox uses IR for their theater remote (buy it), so no issues there. For a PS3 you will need a USB IR dongle, or a Blutooth to IR converter.
4) HAI has their own IR controller, called the Home Theater Extender (HTX), which is a Bitwise BCX4 (don't tell anyone). You will need their 5.7 software along with their automation studio to allow the omnipro to trigger an IR macro (http://www.worthingtondistribution.com/cgi-bin/solutions/yabb2/YaBB.pl?num=1277690443/5)
