PaulD
Just hooked up a Sony XDR-F1HD AM/FM tuner to my sound distribution system (HAI HiFi). I have not been able to get the IR signal to control the tuner (via the HiFi system) as it is supposed to do.
I did some web searches and found some info that indicates it is easy to overload the IR receiver on this model tuner with too much emitter power. I noted that the HiFi emitter specs say it drives the emitter at 100ma. Other tuner user have reported that they have problems with emitters at 70ma and have modified their emmitter setup to run at significantly lower levels to get their emitter to work with this tuner.
The tuner came with a remote and it works fine with the tuner one-on-one but if I try to control the tuner via the HiFi setup it will not work. I know the IR signal is reaching the tuner (via stick-on IR emitter over the tuner IR eye) because the IR emitter lights up brightly when I send a signal thru the HiFi. I tried to move the IR emitter to off-center from the receiver eye and I could very occasionaly get the tuner to respond but I never could find any off-center spot where it was anything close to reliable. I also changed the frequency setting on the RIM to make sure I was using a good IR frequency. Also made sure the HiFi passthru IR mode is turned on.
Bottom line...I am pretty sure I need to somehow attenuate the IR signal because it is overdriving the IR sensor on the tuner. So far, I have tried placing the emmitter a short ways away and have also tried placing various pieces of paper over the receiver IR eye to diffuse the signal. However, I have not come up with a good solution yet. Anyone have an idea on how to play with the emitter signal to adjust it to a level the tuner will accept?
