OK, I have a problem...
In the past eight weeks, I have installed three UPB gigs with networks over a hundred devices (171, approx. 120 and approx. 130). All three have been absolutely HORRIBLE to program. When initially loading the devices via HAI, followed by UPStart discovery, I have LOTS of missed loads. Often, the HAI will "see" the loads but UPStart won't. Other issues include wierd communication anomalies like loads that fail programming and yet, still respond to command lines. Just wierdness. I am also having to run all over the house plugging my PIM into various receptacles and getting varying results from one receptacle to the next. For example, I can program load "A" from one rcptl. while missing load "B" and vise versa. The first was the biggy and I have worked out all the bugs after MANY, MANY, MANY, MANY wasted hours of bouncing around the house to try different receptacles to load from, etc. Those who read my earlier posts on this install may recall that I mentioned that it took a lot of babying to get it but I didn't make any issue out of it as I believed that it was an anomaly that was tied to just the one install. The second install had a second round of programming this past Thursday and I fought like crazy to get it done. Lot's of use of the F word but I dialed it in. Not cool. On this install, I was smart enough to contact Terry at Web Moutain to get some advice and while he was incredibly patient with me, we were unable to figure out the issue with one of my "virtual" three ways. (sorry I didn't get back to on it Terry, I think it may be a bad switch and I think it will be replaced with a keypad style device) Woke up the next morning and went to program the approx. 130 device install. What a freakin' nightmare, same problems, and lots of 'em, throughout. This one is nowhere near done and is absolutely horrible. All three have phase couplers properly installed. All three were physically installed by different electricians. All three are seperated by as many as eighty miles. Used different PIM's. Different laptops. The one constant has been the use of HAI 35A00-1's. Typically in the past, I have experienced 100% loads, 100% programming and zero service calls. From my first install, they JUST WORKED. My questions are....1. Is it the size of the networks causing problems? How will I ever deal with a 250 device install if such is the case? or 2. Has HAI outsourced manufacturing to a new vendor since licensing Gen2? Is the QC a problem? 3. Am I alone in this or have any of you experienced this frustration? It pi$$es me off because HAI just doesn't offer enough margin on the product for me to waste SOOOOOOOOO many hours dealing with this. I need a lower price point than Vantage (I have meetings set up 'em) option and HAI is starting to reek of Insteon as of late...
Any insight?
