Monk
Thought I would take this post out of the "Firmware thread" and give it its own where it might get better vendor attention -
- or better attention in general - I know a lot of you have to be running multiple zone expanders and can possibly chime in with the first part of this anyway.
The situation involves updating the M1G from firmware version 5.1.20 to 5.1.24 - I have reverted back to .20 for the time being.
1.) First I want to describe what I have been considering "Normal" behavior and see if you agree that this is indeed normal.
Powering up the Elk and watching a keypad during "boot" I will see the message something like "13 Zones Not Ready" for 15-20 seconds and then maybe "7 Zones Not Ready" and finally after maybe 45 seconds total just "Ready". The zones it is referring to are split (not evenly) between 2 zone expanders. I have always figured it was a normal part of startup bus communications. Is it?
2.) The bad behavior with .24 involves a change in the (above described) startup. Right off, I get beep beep beep - Zone trouble. It begins with (shown on keypad) the first zone on the first expander. It calls out to Next Alarm to report the trouble and ElkRP's status shows Day Zone trouble. I can stop the beeping by hitting the * key but need to enter the arming code to actually "clear" the error. After which, everything is normal and all appears to function fine. (approx. same period of time passes as in my "normal" startup) Re-downloading does not change anything.
What does anyone think about this?
