J jgershonw1 Member Mar 12, 2009 #1 What are the exact dimensions of the leaf sensor board (LWS1R2B) in mm?
E ericvic Active Member Mar 12, 2009 #2 jgershonw1 said: What are the exact dimensions of the leaf sensor board (LWS1R2B) in mm? Click to expand... The board is 20x40mm Eric
J jgershonw1 Member Mar 13, 2009 #4 I would like to increase the surface area. Would it be ok to connect two of these in series and be still be usable with the moisture meter?
E ericvic Active Member Mar 13, 2009 #5 jgershonw1 said: I would like to increase the surface area. Would it be ok to connect two of these in series and be still be usable with the moisture meter? Click to expand... That should work just fine. Eric
