ddennerline
I have had Leviton Vizia+ dimmers for a very long time. I accidently stumbled across a feature. Maybe I should paid more attention to the manual. If you hold the switch button down for a few seconds, the dimmer will turn on full. In addition, it will still keep its original dim setting. In a few rooms, I typically keep the lights at middle setting. Occasionally, I need full setting. I still haven’t gotten use to the dimmer rocker. So you have to sit then and hold/press the rocker. I think the new hold for a few seconds is slightly better. Just thought I would pass this on….
