Looks like I'm going to need smokes and CO2 units for an ELK system I'm installing for a friend. The electrician said we need a smoke in the new construction portion of the house. So smokes and CO2 sensors are required in the new Master BR and existing LR since the LR is 'on the path' to the new Master BR.
I've read the Bosch sensors are good. I'd like to get a combination unit if possible. Has anyone used the I4 System Sensor Smoke/Co2 combination unit? It looks like it uses an 'interface module' which is wired between the combo sensor (via 2 wires) and the panel (via 6 wires).
