elvisimprsntr
I posted this on UDI forum, but thought it might be of interest here as well.
BACKGROUND
Initially, I looked at adding a USB LTE modem to a DD-WRT router, configure it for dual WAN, add scripts to do the failover/failback, change the IPTABLE to limit what IPs and throttle the BW over the LTE WWAN. While all technically possible, it seemed like a PITA.
So, here is the lowest non-recurring and recurring cost, minimal effort solution I am implementing.
NETGEAR LTE MODEMS
Netgear announced at CES 2017 a new line of LTE modems, ranging in price from $120 to $160. The LB1120 (Bridge) and LB1121 (Bridge w/PoE) will be released on Feb 20th, and the LB2120 (LTE Failover) on March 20th. https://netgear.com/home/products/mobile-broadband/lte-modems/ These are basically the same models as the UK versions (LB1110, LB1111) which have been available since June 2016, presumably with different LTE bands. There was a UK version (LB2110) of the US LB2120, but for some reason the product was either never introduced or pulled from the market. http://www.downloads.netgear.com/files/DoC/204-10950-01_CE_LB2110_EN-EP-FR-IT_20JUN16.pdf
You can pre-order all three devices on Amazon. https://www.amazon.com/NETGEAR-LTE-Modem-Network-Ready-LB1120-100NAS/dp/B01N5ASNTE/ref=sr_1_1?ie=UTF8&qid=1486853740&sr=8-1&keywords=netgear%2Bmodem%2Blb1120&th=1
I was able to find one distributor who already has the first two in stock and is shipping now. Mine will be delivered Feb 17th. http://www.provantage.com/service/searchsvcs?QUERY=netgear+lte+modem&SUBMIT.x=15&SUBMIT.y=15
These units are significantly lower in price than any of the LTE failover products and services on the market (Cradlepoint, Cisco, Sierra, Peplink, etc.) I've looked at them all.
HOW IT WORKS
The first two units, you still need a dual WAN router with failover/failback.. The third model is installed between your WAN router and WAN ISP hardware, it does the failover/failback. There are no US model User's Manuals yet, but you can look at the UK equivalent for the first two. http://www.downloads.netgear.com/files/GDC/LB1110/LB111X_UM_EN.pdf. The product support page for the third UK model was never published.
Not knowing why Netgear never released the UK version of the unit with LTE failover and skeptical how mature the firmware will be, I ended up getting the LB1120 (LTE Bridge). For the dual WAN failover, I purchased a well proven Linksys LRT224 (Dual WAN VPN Router). https://www.amazon.com/Linksys-Business-Gigabit-Router-LRT224/dp/B00GK640D6/ref=sr_1_1?ie=UTF8&qid=1486855892&sr=8-1&keywords=linksys+dual+vpn. It meets all of my requirements, including dual DyDNS. A secondary benefit of the LRT224 is all the complex LAN configuration is now in a dedicated appliance, which reduces my DD-WRT router to simple WLAN APs. Much easier to manage after a firmware upgrade or factory reset.
LTE SERVICE OPTIONS
Now that I have a low cost hardware solution, time to look for low cost LTE service. Since the failover WWAN is a very infrequent use scenario for temporary primary WAN service outages, I really don't need a lot of data. One option was to add a SIM to my existing cell phone data plan for an additional $25 per month, but I wanted to find an even lower cost solution.
IOT PLANS TO THE RESCUE
In the US, both ATT and T-Mobile have announced IoT data plans for companies who want to build products which use very little data and sell the products with services to consumers. I briefly looked at T-Mobile. ATT seemed to offer a lower cost option. With ATT, for as little as $25 you get 1 GB/year. ATT has plans with higher amounts, but if you reach the data bucket limit it simply charges for another data bucket. You can have up to 1000 SIMs under the same plan. Each SIM costs $1 per month. So I registered with ATT as a developer, linking my GitHub account. https://m2x.att.com I bought and already received my 1 GB IoT SIM card. https://iotdataplans.att.com I just have to activate it once my LB1120 arrives on Feb 17th and configure the APN in the LTE modem for ATT IoT (m2m.com.attz) https://developer.att.com/technical-library/apns/apn-descriptions-and-characteristics
CONCLUSION
So for basically a few hundred bucks and $3/month, I will have 24/7 LTE failover/failback for my whole house. My ISY/Elk can continue to send SMS notifications and receive push notifications from third party mobile apps. Another benefit is the next time Comcast raises my internet access rates, I can simply pop in a higher data bucket LTE SIM and tell Comcast to pound sand.
BACKGROUND
NETGEAR LTE MODEMS
- LTE Bridge - US LB1120 - UK LB1110
- LTE Bridge w/PoE - US LB1121 - UK LB1111
- LTE Failover - US LB2120 - UK LB2110 (never released)
HOW IT WORKS
LTE SERVICE OPTIONS
CONCLUSION
