I just completed a DHW and radiant heating system upgrade and am exploring some automation options. I'd like my future HA system to be able to monitor water temps and control a few pumps.
Along with the plumbing upgrade I installed a bunch of 'ports' in various places so that I may install temp probes in the future. I'll be able to monitor storage tank temp, temp coming from the thermostatic mixing valve, temp of the radiant loop from the HX, etc, etc. These temp probes will either be thermocouples or 1-wire temp devices (in thermowells if necessary).
I know, I should first get a HA system in place and then connect the devices.... But I like the engineering design part of the exercise too. And I'd like to think about the remote I/O system as I put together my DHW/Radiant pump relay control. e.g. would the remote i/o provide dry contacts or voltage outputs??
Also, I'm updating the control system to allow a HA system to control various pumps (via relays). For example: Since the primary side of the radiant system heat exchanger uses the DHW tank I'd like to have a timer run the pump periodically even during the summer. This is necessary to prevent things like Legionella... Currently I manually run the pumps in the summer when I think about it.....
Anyway.... I'm looking into options for 'remote i/o' subsystems. I read about the CAI Webcontrol device. It looks interesting.... Is it robust? Any problems with it 'crashing' and putting my pumps into some bad state? What about devices like the 'Click PLC'? And some 1-wire relay boards.
What do folks use for low cost, but robust remote i/o? I suppose I'm thinking of a ethernet link but even willing to consider 232/485/etc. It would ultimately be controlled by some HA controller.
