davidliles
I would like to install low voltage LED lights along the edges of my driveway and utilize various rules to control them based on criteria.
I have an ELK M1 and Homeseer available for controlling the lights... and I'm thinking I could either incorporate a relay with the Elk panel, or utilize a controllable outlet plug to control power the transformer for the lights.
The Elk panel is located in the master closet and the power source for the LED lights will be located in a lower level mechanical room or possibly the garage.
From a novice perspective, utilizing a controllable plug seems like the simplest implementation route. Would there be an advantage of utilizing a relay over a controllable outlet plug?
