M1 +12 VDC power outlet limits.
AnotherOne
How do you get around the limitation of 1.0 Amp current drained from devices connnected to SAUX, VAUX, VKP and J16? Is there a secondary power supply you can add in?
toymaster458
I added a ELK-P112K and moved some of my VAUX devices to it. You do not want to move your SAUX devices unless you setup a relay to reset the smoke detectors.
rfdesq
There's a similar thread running regarding siren power. I'll ask here as well, how do you recommend supplying additional power to two sirens using output 2?
