Jimbo55
Hi all,
Has someone else come across this problem or have a suggestion that may help.
After powering up my M1 system for initial setup I continue to receive this message scroll over & over First - Inside temp, Area 1, & then AC Failure.
Tried turning the system on without AC connected just battery same message.
Initially only the status led flashed & no power led .After changing the AC polarity I now have both Power LED lit up
& Status LED flashing & the AC Failure shows up once only when turned on. Is this error stored in the memory and can be erased?
Or does a fault still exists somewhere?
James
James
