*** M1G Output 2 makes popping noise....
Mp333
M1G Output 2 makes popping noise when a light switch is turned on or off. Also when the ignitor sparks when when you turn the gas stove on. This just started happening few days ago. The only thing that has changed is I have added 4ohms speakers on output 1. Maintained the 4 to 8 ohms in series / parallel.
I read somewhere about using two 2.2ohms resister across output 1. Any body come across this?
Start by removing the new speaker(s) to confirm/eliminate the source of the problem.
Make sure you landed the speaker wires on the Out1 terminals.
Make sure G26 is set correctly for siren or speakers on Out2.
