I'm trying to more thoroughly test my setup, and wanted to test failover from the Uplink 2500 to a POTS line. The Uplink is primary, has worked for a couple years just fine, but I realized I never thoroughly tested it.
The Uplink 2500 is connected to a M1XSP (the special one) and connected to the M1G. The Elk stuff is all current firmware. The Uplink goes to NextAlarm.
The Uplink works fine as primary.
If I disabled the telephone entry for the Uplink in ElkRP, the POTS line works fine. Both have been tested with NextAlarm.
But I wanted to test a real failure instead, so with Uplink primary and POTS backup, I disconnected the serial cable to the Uplink.
I have a rule programmed to announce the lost/restore messages, and cause a 24-hour alarm to go off (and send email). The rule worked fine, the email went, the announcement went.
NextAlarm didn't receive anything.
Waited... waited... nothing. Waited about 5 minutes.
Reconnected serial cable, and NextAlarm almost immediately got two alarms, followed by two restores for this supervision zone.
Did it all again, more carefully -- same result. No POTS line call, but when the Uplink was reconnected the (buffered?) message from the alarm was sent.
I am GUESSING that the M1XSP is accepting the message from the M1G, but can't send it, and is holding onto it. But (again, complete guess) the M1G doesn't fail over because it didn't get an error from the M1XSP.
Now why I get two of each recorded at NextAlarm I have no idea.
Am I missing a step?
Telephone 1 = Uplink = type 0= always report via 7=Serial Expander, call attempts = 1
Telephone 2 = POTS = type 1 = Report to this number as backup via 1 = CID, call attempts = 1 (I intend to increase these later)
And again, by setting each one separately to disabled and the other to type 0, both Uplink and POTS work, separately.
Any ideas?
Any ideas?
