Hey folks,
I'm hoping some can shed some light on this. I recently upgraded the firmware on the elk and all components (a bad move in hindsight). A few things are not working and one of them is the ability to properly send emails via the ethernet expander.
I did some sniffer traces and grabbed logs from the server perspective and the problem is that the M1XEP's initial response to the server's helo is to respond with XXXX instead of a valid command. I've tried both with and without authentication and both have the same issue.
Any ideas? Here's the output from the logs, some info masked:
2006-10-01 20:26:32 <public ip of M1XEP> - SMTPSVC1 ANM04 192.168.250.4 0 xxxx - +<domain>.com 500 0 32 17 0 SMTP - - - -
2006-10-01 20:26:32 <public ip of M1XEP> - SMTPSVC1 ANM04 192.168.250.4 0 QUIT - - 240 234 32 17 125 SMTP - - - -
The sniffer trace backs up the fact that the M1XEP is actually sending "XXXX domain.com" as the response to the mail server. It should be sending HELO domain.com.
Ideas?
Vance
Ideas?
Vance
