I'm trying to work through a problem with my omnistat2 t-stats, here's what's happening:
the t-stats are changing temp's uncommanded, i.e. I change a temp setting via elkrms or ekeypad on a t-stat and the temp setting changes (after 5-10 minutes) on all other t-stats.
I've checked all the obvious items: program settings in each t-stats set to "none"; removed all rules that had anything to do w/ t-stats; disconnected both m1xsp's (all t-stat temp settings were fine and did NOT change);
Anyone else have any sort of problem like this before? I currently have t-stats 1-4 on m1xsp #1, and t-stats 5-7 on m1xsp #2.
