I have a bit of a problem and I was hoping you guys could help me. I have several central ac units that have an overflow outlet with a small float switch that triggers the unit to power off should the drain clog. I want to monitor this with my omnipro ii. The unit doesn't have a pan to monitor and splitting the overflow and adding a second switch would cause the unit to shut down too late. The switch carries voltage so if I just connected it to a zone I would have a problem and it wouldn't work properly. I was going to use a relay that was tied to the power and when the overflow switch is triggered power would be lost and the relay would open causing the zone to trip. That was the best solution I could come up with but there is one wrinkle and that is that when the power goes out all of the zones would then trip. That isn't terribly efficient and not the best way to handle it. Any other ideas?
Thanks!
Neil
Thanks!
Neil
