jrfuda
Guys, I recently purchased some new IR hardware after years of settling for sub-100% reliability from my various IR hardware.
Here's how my new setup is:
Before I had trouble getting IR into the Ocelot reliably, and had to really aim my remotes at my components in order to get them to respond.
Now I can point a remote just about anywhere in the living room, dining room, or kitchen and get a response from the Ocelot or appopriate component everytime! I'm using Xantech mouse emitters with covers on them, so the only way IR gets to any of the components is via the Xantech block.
I have all of the Xantech's outputs on low power, except for the output to the Ocelot, which had to be placed on high power in order to get 100% recognition.
The IR Links provide a safe and reliable way of getting IR between non-like devices and are a piece of cake to install.
The only problem I see so far is that the Powermids may introduce a littl enoise in the system. I haven't confirmed this yet, becuase my second IRLink is backordered, but I have noticed that the Powermid receiver seems to be blinking alot, which means it's getting some noise from somewhere. If the noise ends up making the system less reliable, i will have to switch to an IR-to/from-coax injector scheme in order to get IR from the master bedroom to the living room.
I have order a 3-channel modulator from parts express so I can feed some of the components in the living room to the master bedroom. The powermids or injectors will enable me to control these components from the master bedroom.
Just for giggles I tried learning some IR commands to the Ocelot from waaaay across the room, and it worked everytime! learning IR commands to the Ocelot used to be a royal pain in the arse! This technique works better than using the Ocelot's built-in receiver alone (It's just not sensitive enough) and better than using ADI's dongle (It's even less sensitive). The Xantech block amplifies incoming IR signals and ensures they get tothe components in a high-power format, ensuring recognition - and in the Ocelot's case - accurate learning.
The only catch to this setup is that you cannot have the Ocelot respond to anything that it can transmit itself, or it will be caught in a loop. I only have the 1st 40 spots in my Ocelot setup for IT recognition, and use them as triggers only. I used McIntosh IR codes, since I know I'll likely never own any McIntosh equipment, so they are only used as triggers and never transmitted.
