Well, after a few days of noise and unreliable performance from the PowerMids, I ordered the Xantech IR Coupling/Injecting equipment. Worthington had some bundles that allowed me to add them for about $30 per room with non-CFL freindly IR receivers (which I don't need in those rooms).
Anyway, installation was pretty easy and ALMOST everything worked right away. I think I may have a non-DC passing barrel connecting some cable going to one of my rooms becuase I cannot get my equipment to respond to commands from it, so I may have to do some attic crawling this weekend to track it down. My "Master Bedroom" and "JC's Room" remotes work perfectly, however.
While I was playing with cables, I went ahead and installed a 10db amp I already had in the place specifed in my diagrams, I also installed a high-pass filter that I already had to help with some of the herringbone patters I was getting in my modulated pictures, which I beleive to be noise created by my bidget-priced modulator. Well, it worked. I leveled the playing field between by Dish DVR modulated and modulator modulated channels and now have crytal clear pictures on all five modulated channels (21, 50, 62, 64, 66) in all rooms. SWEET!
I'm very pleased with the setup. The wife and I have already used the feature to watch the last 20 minutes or so of two movies we started in the living rooms and finished in the bedroom.
EDIT: One thing to note... The Xantech hard-wired over existing cable scheme is not completely noise free. I do see the emmitter coming from the coupler blinking every once in a while when there's no one sending signals in the other rooms - I can tell the noise is coming from the cable and not from the rooms, becuase the "receiving IR" LEDs on the receivers in the remote rooms are NOT blinking. So somehwere among the various injectors, splitters, and the coupler, some sort of DC noise is being generated that is being intepretted by the coupler (which feeds the emitter) as anIR signal is being generated. The noise is minimal and does not affect performance at all, however. I'm going to eventually remove the emmitter from the coupler, replace it with an IRLinc (the one I had is being RMA's due to a defect) and hard-wire it to my connecting block - then I won't even notice the noise 'cause I won't be able to see it
