Personally here went with the OmniPro 2 related mostly to footprint and defaults integration.
I continue to utilize X10, Z-Wave and UPB. Other users here on the forum utilize Zigbee.
Relative to my use of automation software and integration to my OmniPro 2 I consider the OPII a controller on steroids and if not utilized with software then just a functional combination security automation panel.
IE: I can integrate the Amazon Echo control of the HAI controller widgets via Homeseer.
What the two panels can do typically will satisfy basic automation needs and long time established security methodologies.
The lights, thermostat, audio will work just fine on a schedule or via simple zone triggers.
The additional use of software addendums provides the added eye/audio candy for those in the want or need but really it doesn't change the basic functionality of both panels.
Personally here the stall (procrastinating) related to the time when I could do this. I did turn each piece in to an individual project of sorts whatever it was. Well like pulling one wire (catxx) post install from the basement to the attic across the attic then down to the second floor. By the time this was done; I was done for the time allotted. The next piece didn't occur for a week or more. That was just terminating the ends and testing them. 1 (one) PIR installation was the same. So was one pair of speakers in one room with a control pad. I did prioritize what I wanted the soonest. I added a surge protector to the outside AC compressor. Disconnected the electric first. This endeavor had me removing all of the electric, adding more wires and then redoing the electric. It was mostly easy. Most difficult here was related to the gauge of the electric wires. Thinking I started at 0700c and was finished by 0900c.
The mention of a bathroom audio installation. Here just put in two in wall speakers in the master bathroom and a control pad and an AB switch. Initially it was connected to the local AVR; then later the zoned audio. I wanted it fast so it was prioritized and done within just a couple of weeks. All of the LV wires came from the attic down.
