Charmed Quark Systems, Ltd is proud to announce the 1.6.15 release of CQC (the Charmed Quark Controller), its software-based control and automation system.
Charmed Quark System's automation products provide robust, flexible, and cost effective control of lighting, HVAC, security, home theater, media data, and other systems. It is available in various configurations, which will scale to meet your needs, whether large or small, open or secure, a single room or the whole home. Build your own hardware, or use our pre-built systems. Do it yourself or pair up with one of our integration partners, whatever fits your needs and budget.
What's New
Version 1.6.15 is a refresh release that brings in some moderate fixes and features that didn't make it into the original 1.6 release. A couple of the new features though were very much requested. The most significant new features are:
What's New
- Metadata Browsing. In previous versions, metadata was only available for the currently playing media, but now you can add metadata repository browsing widgets to your interfaces so that you can preview media before playing it.
- Omni Pro II Driver. There is a new ethernet based driver for the widely used Omni Pro II automation panel, so CQC now has strong support for both the Elk M1 and HAI Omni panels.
- Dynamic Field Assignment. The user interface system now supports dynamic field assignment which allows you to reuse a single interface template for multiple zones or multiple devices, and other situations where multiple identical templates would have been needed before, the only differences being the device/fields referenced.
- User Action Event. A new broadcast event has been added that allows button presses on controlled devices to invoke a configured CQC action. Some devices provide such buttons that are just intended to cause user defined actions, and if the driver can be informed of those button presses, it can send these events.
- DVDO VP30 Driver. There is a new driver for the DVDO VP30 video scaler/switcher, the followup to the iScan HD which CQC also supports.
- System Volume/Mute. You can now control the Windows volume level and mute settings, for those folks who are using CQC in an HTPC type configuration.
- Slider Widget. The interface system now supports a slider widget which can be used to set or display device values graphically, complementing the exising rotary volume knob widget.
- Interface Variables. You can now set variables in the interface system, which can subsequently be used in other invoked operations. This allows for a lot of flexibility, particularly when used in conjunction with the previously mentioned dynamic field assignment capability.
