Just purchased a new M1 gold with a dbhr and ethernet connection so I can swap out a 13 year old brinks system (BHS 2000).  I have 3 keypads (Ademco) to replace, 2 smoke (4 wire), 3 CO2, 1 motion and 35 doors and windows (I will cluster into 9 zones). None of the doors or windows have an EOL resister, but it sounds like this is not a big deal for a private home.
I already have a nice insteon dual band system (about 30 switches and outlets) run through an ISY and want to integrate this with the M1. I have looked through the M1 manual multiple times and will be setting this up this weekend.
I do have several questions:
1) What do I do with the 2 extra wires at the keypad, as I am just using a 4 wire system with the DBHR? Just cap them?
2) With 3 keypads, do I wire all 3 and then go back to register each of them or do I need to wire and register 1 at a time?
3) I won't have anything going out of output 2 on the M1 and in one place it talks about looping a 2200 ohm resister in this space to avoid "problems", is this correct?
What else am I missing to avoid surprises?
