RAM
I got a 5 kw solar panel setup fired up last week and now I'm seeing my normally well behaved X10 setup randomly turning on devices when the panels are producing any solar power. I'm sure it's line noise being introduced by the solar installation (probably the micro-inverters) that is being seen by my devices as a turn-on signal. I know it's not a clean X10 signal as Homeseer isn't showing that the deices should be on.
Anyone have a solar installation and X10 and are you seeing anything similar?
If so have you found out what to do to lessen/eliminate the problem.
I contected Jeff Volp and he suggested the X10 XPF 220v line noise filters. But since my array puts out more that 20 amps, one 20 amp filter won't cut it.
