New terminal blocks on M1G?
jruben4
This may be a dumb question, but how do I connect the sensor wires to the M1G? It looks like it has a new type of terminal block that doesn't have the tightening screws anymore, but just round sockets with a pin at the bottom.
I wonder if these terminal blocks were updated? The manual shows screw-type terminal blocks like I've seen people post before in pictures of their setups.
But I just got the Elk M1G today and it has a different terminal block. I was trying to figure out if I need these yellow-jacket "B" splices, it kind of looks like they would take a wire and put a connector on it like i need to plug into the board.
If it's not clear what I'm talking about I can post a picture.
Thanks..
The other end of the blocks should be in a bag. They have the screw terminals and they plug into the board
I think I figured it out. They weren't included since I got
ELK-M1GCB. I think I just need to order​
ELK-M1BLOCKS and they will plug into the plugs I'm seeing.​
Where did you get your M1G? AFAIK, they all ship with these blocks, if these are missing, then I would be a little worried about what else might be missing/wrong.
The model he ordered is intended as a replacement board and does not come with terminal blocks. The distributor should have that noted on their website.
It's pretty clear from the ELK website that the
ELK-M1GCB doesn't come with terminal blocks. I didn't get that from the distributor website though, hence my confusion.
