Omni LT modem problems
alpalmer
I just got a new computer and have installed PC Access on it. The computer has a modem which works. I faxed some stuff out on it. However, I cannot get it to access Omni. I used the program with no problems on the old computer so I know the system is accessible. I have checked the com port of the modem and it is correct in Access. I have tried to initialize it. I am using Windows 7 64 bit and wonder if that is the problem. Any help would be appreciated.
Thanks for your help. I opened up my old computer and copied the strings from there. Actually, the problem was the connect string that contained my log on password. It needed the additional 1 to access the system. Put it in and it worked fine. Thanks again.
Al,
I suspect that your new modem may be having trouble connecting via the Bell 103 300 baud standard that the Omni LT uses. This HAI Knowledge Base article may help some: http://kb.homeauto.com/default.asp?id=126&...SID=&Lang=1.
