I have an HAI OmniLT with an HAI RC-80 thermostat.  I cannot make temperature changes with the phone, either by hard line or my cell.  The Omni and the thermostat are communicating.  I have programmed temp changes and it makes those.  The temp and thermostat settings come up if I do a status check in PC Access. So I know the two are communicating.  I can call in to the system and it connects. I get the voice menu.  "Enter temperature then pound." However, if I try to make a temp change, I get the three beeps and no change.  It will do other commands such as "all on," with no problem.
I have checked the thermostat. The address is set to 1. The communications mode is also set to 1. The Display options is set to 5. The setup/Dial/Remote Commands OK is set to Yes.
It seems as though the phone interface is working and there is communication between the panel and the thermostat. What have I missed? Any help appreciated.
