I am trying to convert my X-10 system to UPB and cannot get the switches to configure.  The data:  I have an OmniLT (3.7) with PC Access (3.10.0.643) running on a Windows 7 (64bit) computer.  I have replaced all of the switches with HAI 35A00-1 and am using an HAI PIM 36A00-1.  I started a new file in PC Access with new Unit names and numbers.  They all reflect UPB room and unit numbers.  I was able to upload that to the controller.  All of the new names, etc., come up on the console.  I have tried to configure the switches with both House Code Settings, i.e., Setup/misc/house code set to HAI Lighting and set to UPB.  With either setting, I tap switch 5 times, it goes into blinking mode.  I go to setup/control/ find the appropriate unit, press # twice.  It indicates that configuration is starting.  However, it never stops.  I do not know how long it should take to configure a switch but I have left it until the switch defaults out of configuration mode (5 minutes).  I have tried all of the switches - none configure.  What am I missing here.
In the middle of all of this my PCAccess stopped accessing the modem. It has worked flawlessley for over a year. All of a sudden it will not link up. I had not been doing anything with that in the way of changes and it had been accessing fine as I worked on this the past two days. I reinstalled the modem and upgraded PCAccess to no avail. It dials, rings, the modem picks up but nothing else happens. Baud rate is 300 and com port is 3 which corresponds to the system settings. The modem checks out with system diagnostics.
Needless to say, this has been a very frustrating two days. I would really like to get this system working again.
