I am getting myself ready to install an Omnistat 2. (As soon as I work up the fortitude to go back in the attick and start dragging cable in walls again).
Installing one looks pretty straight forward.
If I want to add a second elsewhere do I need to connect it to the HVAC control wiring too or can I just home run it to the HAI panel and the 2nd Omnistat can talk to everything via the panel?
I'm not sure of the proper way to add 2nd and 3rd units.
How do the multiple units deal with temperature settings? Each one has a temp sensor and I am sure there will be different temps in different rooms. If you set one does it set them all? At this point I have a single zone (no dampers or anything fancy) AC + furnace systme (in Socal).
I am just a bit confused how it all works together.
