SierraTech
I never ran into this before after updating my firmware last year (don't recall if I tried to set the clock either). Below are Firmware and Software revisions:
PC Access: 3.17.0.843
Omni II Controller FW 4.0b
I connect PC Access using Network, and double-click "Controller Time" and I receive, "Unhandled exception error has occurred in your application........."
Value '1/2/2021 2.29:16 PM" is not valid for 'Value'. 'Value' should be
between 'MinDate' and 'MaxDate'.
Parameter name: Value.
I attached the screen capture. Any ideas why I receive exception error, looks like it's looking for Date, not Time?
Happens on Windows 10 as well!
More detail:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Value of '1/2/2021 2:47:00 PM' is not valid for 'Value'. 'Value' should be between 'MinDate' and 'MaxDate'.
at System.Windows.Forms.DateTimePicker.set_Value(DateTime value)
at PCAccess3.frmPopUpEditDateTime..ctor(clsHAC _HAC)
at PCAccess3.frmStatusSystem.Command_SetTime(Object o, DataGridViewCellEventArgs e, String HelpKeyword)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.DataGridView.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8762 (QFE.050727-8700)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
PCA3D_EN
Assembly Version: 3.17.0.843
Win32 Version: 3.17.0.843
CodeBase: file:///C:/Program%20Files%20(x86)/HAI/PC%20Access/PCA3D_EN.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.8770 (QFE.050727-8700)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 2.0.50727.8771 (QFE.050727-8700)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 2.0.50727.5494 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
7as-nmm0
tce8-9ah
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
More detail:
mscorlib
PCA3D_EN
System
System.Drawing
System.Xml
7as-nmm0
tce8-9ah
enabled.
For example:
<configuration>
</configuration>
