Hi All,
In preparation to add a new ELK-M1XRFTW to my Elk M1 Gold system, I moved my M1XIN from address 2 to address 3. After doing an enroll in RP, the system added Hardwired Exp3 and zones 033-048. I then right clicked on hardware Exp2 and selected Remove Hardwired - Exp2. Then I clicked send all to the system.
Then I check for conflicts and its says there are zones 016-032 in the system that are not in the database. I select all and then select receive to database and Hardwired Exp2 is back.
Do I need to change a jumper terminal? or what am I doing wrong?
Thank you
Thank you
