treo650
Per my understanding, ELK J16 pumps 50mA output, will it work with this photobeam sensor>?
http://www.gatedepot.com/get_manual_file/14107/
(note that the photobeam above will work with 12V-240V)
**I have a small dog in the garage, he likely goes to the attached house door to "call" us when he needs to use the restroom at night, so I plan to have the beam sensor across the door when he is near, and the ELK will text me for notification.
1) will the above photobeam sensor work? OR is it a better idea for me to use a PIR motion detector instead?
2) How will I wire it to the ELK M1 board? OR an M1XOR should I buy one in the future?
Problem with a PIR motion is, I currently only have two strand wire to the location, and not the necessary 4 wire needed for PIR
