dhoward
I would think group commands would be used primarily for scenes (or as you say to keep KPL's or 3-ways in sync) but I see your point. The great thing about groups, is the variable ramprate (preconfigured in the group definition, but variable at the time the group is created). The downside would be the limitation on specific dim levels (variable when the group is created). With a direct command, you could instantly go to whatever level you want, but only at the preconfigured local ramprate.
I wouldnt think that a group command would be any more reliable that a direct command. A group command is first a broadcast message that is not acknowledged followed by individual group cleanup (direct) commands that are acknowledged. The direct command is the same thing minus the initial group broadcast (the commands are actually different, but both are direct commands that are acknowledged.
Now talking about this has just given me a new idea (no idea emoticon).
You can get even more usability out of your groups by "slicing" them up! A standard direct command tells a device to go to a specific level using the local ramprate. A group cleanup direct command tells a specific device to go the group level using the group ramprate. You can use group cleanup commands without first sending a group broadcast. This way you could control individual devices within a group using the group level and ramprate. I'll be adding a new function/command to PowerHome so you can send a group cleanup command (not sure if many would find it useful, but it's easy enough to add) without the group broadcast.
Dave.
Dave.
