I'm having problems getting good data trying to read the barometric pressure sensor on the B1-R1-A board.
When I attempt to read the VAD pin, the voltage reading that I get back is 10.23V, which is 0x03FF in the result. I'm pretty sure the code that's reading the sensor is working, as I can get a temperature reading that looks OK; I can read the 2438 VAD voltage on two temperature/humidity sensors OK. Also, when I move the jumper on the board between pins 1 & 2 and measure the calibration voltage, I get a reasonable 3.45V measurement.
I'm powering it with a power injector, measuring VDD with the 2438 give me 4.93V, which seems pretty reasonable. I'm using an HA7Net to drive the 1-wire bus, and one of the H/T/S boards is daisy-chained on the same leg, a few inches away.
Any ideas on what's going on, or what I might try next?
Unfortunately, the board is about 180 miles from me at the moment (of course), and it will be hard to fiddle with the hardware first-hand. If I was there, I'd drop a voltmeter on the sensor output and verify the +12V output of the regulator..
louie
louie
