smolino
I'm having a problem setting up a Resolution RE105 temperature sensor. This is a wireless GE Crystal compatible sensor that has two transmitter ID's, the default ID for low temp, and a 2nd ID for high temp. The low temp ID is printed on a label inside the sensor, the 2nd ID has to be "learned".
My alarm panel is an Elk M1G with an ELK-M1XRF2G receiver.
I can cause the Elk to learn the 2nd ID using the procedure described in the M1RF2G manual and then when I connect RP, I see that the transmitter ID has been inserted in the appropriate field however when I open the tamper switch, that zone does not go non-secure. I have many wireless transmitters and do not have issues with any others.
If I program the zone for the default transmit ID, the tamper works as expected. The instructions indicate that the tamper switch should create an alarm condition on each transmit ID.
I purchased three of these and have tried each of them with the same result.
Any thoughts as to what the problem might be? Does anyone else have experience with this device. What else can I try?
