"sdeens, we'll have to agree to disgree then. You aren't getting what I am saying."
That has nothing to do with it at all, your setup is LOCAL and ours is stricktly remote. apples--oranges
I do believe you just proved his point, sir.
I'm going to give this one shot and I'm out.
You seem stuck on this concept of 'marrying' the Quatech hardware to a particular machine, like it was a bluetooth device or something. It's just a box that listens for signals coming in on the ethernet port - it doesn't need to be 'married' to anything to work. All it does it listen for a signal that it understands and respond accordingly - no marriage license required. When you load the drivers on your computer, you're allowing the computer to utilize the hardware by allowing it to send signals the Quatech is looking for - nothing more exotic than that. Think of the Quatech like a web server... because that's really what it is. You don't establish some trusted two-way pairing when you pull up Google, you just send a request that it knows how to answer. This is the
same thing, you're just sending a request using their drivers instead of with a browser.
do a hard 30 second HARD reset using the paperclip-pin in the back of QUATECH at the REMOTE location only and do it twice forgood measure until all LEDs flash rapidly and you may lose that original REMOTE negotiation to it.
Perhaps you don't realize it, but what you're doing is a factory reset to defaults... which would explain why you can't reconnect to the box after you 'hard reset' it. Don't take me at my word, check page 15 of the manual where it clearly states "To restore the SDS to the
factory default configuration, push in and hold the Reset button."
I am able to connect to my remote serial ports at home from within my corporate environment - that means going out through at least 3 switches and 2 routers just to get to their fiber provider who utilizes a good 3 hops through routers to get me down to my local ISP where I go through yet another router before it make it into my trusty linksys. It works, I promise you... as long as you have your router setup to allow the connections in and your ISP isn't blocking inbound connections on your selected port, then Bob's your uncle. Obviously, you want to create a secure link as Dan has outlined if you're doing this on a more permanent basis.
Good luck.
