brettahale
The current panel that I'm replacing, old Radionics, has 4-wire viper vibration sensors home run from all the windows, plungers & vipers in series from the doors and motions.
The seem to be no EOLRs installed at the windows and doors, they are installed in the panel. Any series of sensors are also wired from the panel home runs. It looks like all windows on each floor are a zone, each door is a zone and there is a CO zone. The door zones are each a vibration sensor and plunger in a series.
Assuming the vibration sensors haven't been turned on in years and they are older than that, should I replace them or test and use them? If I don't have to replace them, no need to be wasteful. But, if it's time, it's time
If I keep the existing sensors, can I wire contacts in series?
If I don't keep them, can I wire other glass break / vibration sensors with contacts in a series? What's the ideal combo? I'd like to use the existing 4 wires if possible.
At any rate, should I put EOLRs at the windows & doors? If yes, any resources about the best way to handle it?
I have Vista 20P panel, no zone expander as of yet but can get one if necessary. Any sensor recommendations would be great. While we're on the subject, I need to replace the CO sensors as well. The plugin units are falling out of the sockets and driving us crazy. So, recommendations for that and a few 2/4 wire smokes would be helpful.
Thanks yet again!
Brett
Thanks yet again!
Brett
