Quick help: Can I use LV boxes for keypad locations?
Shag
Pulling cable in my place starting later today, and just thought of something - can I use LV boxes for the keypad locations, or does it have to be a closed electrical box?  The keypads will be powered via cat6, and not sure how that plays into code requirements.
Thanks!
Unless it is a fire rated wall, you can use no box (just cut a hole in sheetrock for the wire and screw the keypad to the wall), LV, or HV box.
If you are doing flush mount keypads, then a standard box may not work, you would need to use the vendors box.
Also you do not need jboxs for LV wiring, it is better to use the LV rings.  An LV ring makes it much easier to terminate without violating the bend radius of the wire, especially for coax.
#3, anything is fine, no requirement for an enclosed box, for low voltage.  Open back LV ring for category cable is preferred to an enclosed junction box - no tight bends in the cable.
Here is a picture of what I use in my home today; likes and dislikes.
Aside from the touchscreens utilize Russound keypads, externally mounted speakers, and a couple of LCD TV's (under the counter and laundry room) and a few more around the house for this or for that....
Wow the rest of us are going to have to step it up on the "info-graphics" front from now on Pete...  :D
Yup bored a touch here.
The ultimate is the whole combo graphics, text which illicites documented somewhat unique physiological reponses to the human psyche (the intangible)  without even much of an effort these days....
I've used the Carlon orange old work LV rings, single and double gang, from Home Depot, exclusively.
If you tighten them down, so the ring digs in a bit to the the drywall surface, they work well, in my experience.
Pete, why don't you like them?
I was wondering that too looking at Pete's pics as they look fairly similar - except the single gang boxes he showed, the one he likes clamps in the center top/bottom and the one he doesn't clamps in the corners... or those orange ones seem to keep the wallplate from sitting flush - tends to stand off the wall just a hair.
Yup; the orange ones stand off the wall a bit too much.  Concerned too that if I crank on them they might damage the drywall.
Never paid attention to the part numbers.  I did mostly buy these at the three local big box hardware stores; Lowes, Home Depot or Menards.
I also was purchasing the in wall dual and triple with HV/LV boxes for a while at at same said hardware stores when they were less than $20 each.  The prices of the in wall boxes though went up to some to $80-100 such that the last ones I purchased came from the internet at a reasonable price.
One of my last LV endeavors I did use a combination of various means (LV boxes / mud rings) for a clean setup for my 36-37" LCD TV mounted near the ceiling of my home office.  The LV wiring pieces was the simplest part of the endeavor.  I did put electric running a new circuit there.
The most difficult part really was mounting the TV set that high up without dropping it climbing on a little short ladder.
There is LV stuff behind the LCD TV and a few feet away from it with connections directly to the LCD TV from the comm closet two floors down in the basement, another room and same room. (HDMI, Network, RG6, audio, USB et al for a bit of experimenting)
