Two questions regarding the RC-80B.
I have 3 RC-80B's running flawlessly. Well, almost
Typical programming for each: higher HSP in the morning, lower during the day, higher in the evening, lower at night. One tstat always jumps to the higher HSP at midnight. Can't figure out why. I had this problem while running PCA 2x and reprogrammed when installing PCA 3 and still have this problem. Since it's only one tstat and I had the same issue under PCA 2x and PCA 3, is there a setting in the tstat that I'm missing?
Second question. At one time I used to be able to access a variable that showed when a tstat was calling for heat and when it wasn't, ie. furnance on/furnace off. I can no longer find this variable. Is it still available somewhere?
Thanks in advance. I searched the forum but found nothing similar to these questions.
Rick
Rick
