felixrosbergen
Hi Photon,
Thanks for your contributions, I will seriously investigate 66 blocks as wel. They also appear to be a cheaper option.
On a 66 block i would think that if i terminate all the field on the 4th column and al the wires coming from the M1 on the 1st column i can then put bridging clips in for all correct? There's no real reason why the left and right shouldnt line up, at least not iniatally (untill the inevitable changes). Ofcourse this would mean i'm using twice the amount of pairs.
For needing about 50 pairs (100 wires) to be cross connect it seems i would need 2 'Split M' blocks and 100 clips. http://cableorganizer.com/leviton/wiring-s...ock-50-pair.htm
I wouldnt not expect too much to change on the field wiring side. With the 110 solution i woudl leave off any unused C4 clips, worst case not al wires of a C4 would be used and i have to skip a few rows and use the new C4 connector when i have to add something later.
Choices, choices, choices... fun stuff to think about though
You point about using only female punchdown keystones for LAN is well taken...i was planning this in general for my LAN connections (keystone at the wall and 19" Cat5/6 modules rack with 110 punchdowns at the wall mount rack). I may try to make my own Patch cables though since within the ELK can and other places i want to cable lenght to be close to right so there's no excess.
