DavidB
Haven't seen a SPST relay in long long time, and didn't catch that the relay board had them instead of SPDT. I was going to use this to control my Thermostat. But I want the Thermostat inline still incase the computer fails or relay board fails. So like for winter have the Thermostat set to 40F just incase. I had it all drawn out with SPDT relays until I realized my mistake before actually starting.
Now, with the picture below, this would all work fine if I made sure the Thermostat was changed to not come one at for example until 40F. So likely hood of it supplying 24vac is low. But what if I forgot to and the relay board and the Thermostat came on. I haven't been in school in awhile, so forgive me if my theory is off. But I don't see any good coming of this if the thermostat turns the blower on and the relay board does also. Even if they are in phase (the 24vac is from the same source (ie the furnace)).
If I am wrong let me know. But I think I am going to have to use the relay board to control other relays to do the job of keeping the Thermostat in-line, but switch the blower, ac, heater. My initial design left 24vac going to the Thermostat, but switched to NO contacts to supply 24vac to the furnace relays and leave the NC to the thermostat, just incase relay board or computer failed. But without the NC contacts can't do that.
I designed another way to do it with the relay board, but that involves keeping two of them switched on all the time, I prefer to keep NC as the default so don't really want that either. That way if the relay failed the thermostat still controlled.
Not wanting to damage my furnace transformer during the winter so thought I better ask.
Thanks, Dave
Thanks, Dave
