Hey Guys!
I have a water well house that this 300 to 400 ft away from the house. The power pole is located between the house and the water well. A single 4 conductor line with 2 phases goes out to the well. A few weeks ago i noticed that the pressure tank was water logged. I noticed this by accident because I happened to walk by the well and realized that the pump came on and went off in short intervals. I fixed the water log but I was wondering if you any suggestion on how I can monitor the pump and/or pressure with my Insteon network.
tonti
- I think I can measure amperage to see when the pump is on. Any suggestion which sensor to use?
- I could possible use a relay that gives an open/close signal to a Smartenit input relay?
- I could use a pressure switch, any ideas what to use?
tonti
