Are there any restrictions regarding zones/relays/outputs/alarms/sensors/etc. that are remote to the M1G (i.e., hooked to the M1G via the data bus hub)? I know the temperature sensors can only be connected to zones 1-16. If I have a second building set up as "area 2", and the only connection between the Elk hardware in the second building and the Elk M1G in my home is the single RS-485 connection between the two of them, are there any other things I can't do in "area 2"?
Ira
Ira
