Looks like my HA/security/etc. solution will need a raspberry pi. HA will be done by a Hubitat hub (mostly using z-wave devices). Security will be handled by an Elk M1 integrated with Hubitat. Apple Home/Homekit will front end everything and provide the UI for iPhones and iPads. Hubitat will be a bridge into Homekit for the z-wave devices and the Elk M1.
I've been playing with Reolink POE IP cameras, and that will probably be the security camera solution I use, including a Reolink NVR. Unfortunately, Homekit doesn't support POE IP cameras, nor does Hubitat. That means I need another bridge device. From what I have read, the best bridges for the cameras are Scrypted and Homebridge, with Scrypted seeming to have a slight edge.
Homebridge can be implemented as a pre-built, pre-installed, single purpose appliance by buying the "Hoobs" device. Unfortunately, Scrypted is only available as a software download (which is free and open source).
Scrypted can run on various computers, but I want to implement it as close to a single purpose appliance as possible, i.e., no monitor, no keyboard, no mouse, etc. Just hit the power button and a minute or two later it is running and working (like Hubitat, M1, firewall appliance, cable modem, etc.). That's where the rPi 4B comes in.
My questions...
Ira
My questions...
- Is it possible to purchase a pre-built rPi 4B with 8GM memory and pre-loaded with Linux? If so, where? Everything I've found comes in kit form (some with case included) without a OS.
- Once an rPi is bought/built, and the OS and Scrypted software have been installed, is it easy to configure it so that it can be treated as an appliance? For example, if I have to reboot it, I don't want to have to ssh into the box and go thru a Scrypted or Linux shutdown, then go thru a startup process that requires me to log on to the box after Linux reboots, start Scrypted, etc. I just want to be able to press the power button to shut it down, then press it again to reboot (like the Hubitat, Elk M1, firewall, cable modem, etc.).
Ira
