Remove/unenroll transmitter on Elk M1
skyphyr
Hi all,
So I got my the honeywell receiver up and running, but a motion sensor registered twice, so it's on two channels (I don't believe it's a multichannel device), and I haven't been able to find a way to remove the enrollment which I don't want.
If I try just go over it, then I get an enrollment not authorized message, but I've not been able to find details anywhere of how to delete enrollments. The closest is to set the zone to disabled, which it is, but that's doesn't remove it and free up the channel.
Thanks for any help.
Cheers,
Alan
I believe the trick to deleting the transmitter is to set the Loop number to 0 in the Wireless Setup pop-up window in RP.
To get to the pop-up window, select the Wireless Zone from the zone list on the left.  Then click on the Wireless Setup button in the right pane.
You can also set the loop number to zero via the keypad. See page 11 of the M1XRF2H manual.
The only other option I can think of, which would certainly be more painful, would be to completely delete the wireless group then add it back.
Hi RAL and drvnbysound,
I had to go build a win 8 pc yesterday because all my machines are win10, so no ethernet access on that firmware. Such a pain installing a PC just to update firmware. I'll give it a swing through the remote software, see if that's easier than the keypad.
Thanks for the pointers.
Cheers,
Alan
