Replacement antenna for W800RF
hobbes487
Anyone know where I might be able to find a replacement antenna for a w800rf receiver? I seem to have lost it during a move and I need a new one.
I suspect any short piece of metal would be fine. I could measure mine to give you an exact length if you like.
Sounds to me like a GREAT time to just build yourself one of thse: http://www.cocoontech.com/portal/articles/tutorials/home-automation/10-how-to-improve-your-x-10-rf-reception
For a few bucks in parts you can have an awesome antenna with considerably more range. I added one and I went from having trouble 20ft from the receiver (through walls) to having no trouble anywhere in the house, including in the driveway or back yard. With a beefed up transmitter some have gotten in the hundreds of feet in increased range.
WGL sells them and I saw Smarthome also carrying them.
http://www.wgldesigns.com/w800.html
http://www.smarthome.com/31252/WGL-Designs-40020-Replacement-Antenna-Bracket-and-Cord-for-W800-Series-X10-Receivers/p.aspx
Sure, I can look it up. I just didn't want to go through the effort if you were interested in something else...give me a bit.
Here it is:
http://www.radioshack.com/product/index.jsp?productId=2103641&cp
It's basically the same thing that was pointed out above (the build your own).
I think I bought mine on sale at some point.
You will need an adapter to go from the "port" on the bottom of the antenna to the coax style.
While I was looking it up, I realized in the new house, I am not using that. I am only using the 1/4wave whip that came with the W800. My LAST house it was NECESSARY (I had metalized insulation). This house...I can get DS10's from 1.5 houses down the street...using the 1/4 wave. I did use it at the last house, and I went from barely able to get a KR15A(?) from the edge of my property to 2 or 3 houses away.
--Dan
(?)it is the security keychain remote from Radio Shack...same as the X10 version, but nicer form factor and 2 light controls besides the Alarm / Disarm)
I'm an idiot. While I have a W800rf, I was picturing in my mind the antenna from the ELK Wireless expander which is really just two short pieces of metal. The other responses are correct however.
Here it is:
--Dan
Happen to remember if you trimmed the elements to 310MHz? I just ordered one from the Shack. Also, RS' docs don't show the connector. Can you tell me what it is? TIA
TECH SPECS Tab: Says it has a SO239 connector on it. So you need a PL259 to mate with it or an adapter to connect your cables connector to a SO239 female connector on the antenna.
Users manual:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000176_PM_EN.pdf
You are welcome.
That is the same antenna that some X10 forum members. Used on their CM15A with external antenna modification.
Wow - considering the range I was seeing before adding this, I'm impressed... I couldn't get the cheap keyfobs to work 20ft away. Did you try anything other than the DS10's?
I use a few of the eagle-eye motion sensors; stick-on decora-looking 3-device switchplates, and those little slimfire keychain remotes - but on all of them the range was absolutely dismal without BraveSirRobbin's antenna. However, even with it, the cheap switchplates only work in my driveway - no further.
I found one of my pro palmpads yesterday - I should fire that up and see what kind of distance I get. Regardless, I definitely recommend a better antenna - either BSR's or the radio shack one - whatever increases range - which in turn increases reliability.
