bbsux
I have a Eden Pure heater that I have used for the last 3 years to heat my bedroom during the winter. It works good but the thermostat is the old honeywell (analog) dial type of thermostat. I assume its exactly the same as a house unit.
I'll describe how the unit works stock in case anyone doesn't know.
It has two quartz bulbs encased in copper heat chambers, which air is blown by and out the front of the unit. The unit's fan (which I've replaced once with a new one in the time I've had it, just a box muffin fan) stays on about a minute after the heat shuts off to cool down the copper chambers and bulbs, (I assume it has a control board that does that but I don't remember seeing it).
I'd like to be able to setup like 3 or four temp sensors around my room and average the results (or something) to allow the webcontrol to be used to control the eden pure.
I mean I could just use it to turn a Solid state relay on and off but that could be bad because of no fan cool down period.
Primarily I want to do this to be able to set the unit lower when I go to work, plus have a different schedule on the weekends.
